Advise on R2R DAC
Useful information, thank you.
My current RCA cables are Mogami neglex 2497 which was suggested to me for a warmer sound. I might looks at a neutral/bright cable now. Any budget suggestions please?
Also, I am planning to bring the Anode Acoustics tube pre. Will try out different combinations with DS DACs and the Metrum Octave, hopefully over the weekend.
I have upgraded from Mogami 2549 to Oyaide Neo D+ Class A RCA Cable.
If someone carry for you from Japan, it will cost less then 5k.
I am using it between Areas 2 and Naim Nait 5si.
Oyaide Neo d+ RCA class A
I am using Mogami Gold RCA interconnects and AudioQuest Rocket 22 speaker cables with the Kinki Studio. Tried the Mogami 2477 speaker cables but the resultant sound was mushy and dynamically subdued vis-a-vis the AudioQuest Rocket 22 which sounds big, bold and expansive in comparison. I also use other Mogami speaker cables such as the 2972 but they’ll probably not be my top pick moving forward.
No need to change RCA cables. Use a thinner guage speaker cable. Thinner guage speaker cable will handle higher frequencies better. For ex -- if your current speaker cable is 12 Awg, use a 14 Awg speaker cable for better higher frequencies.
My speaker cables are Mogami 3103, Belden 8477 and DAC SPY211, all looks like 12 awg. In 14 awg, available one is AmazonBasics cable which used to sell for 2k for a roll.
Since you already have 3 different speaker cables why waste more money on speaker cable just get an graphic Equalizer. It can be more effective in taming bad frequencies.
A physical analogue Eq OR a DSP based Eq since I use RPI 4 to cut the cost? Any advise here?
DSP based Eq will cost you more if you opt to go with DBX or Minidsp. 15 band analogue Eq or 31 band analogue Eq will cost less. With DSP based Eq you have lot many ways to tame the sound as per your liking. You can also use RTA in conjunction with Parametric Equalizer to shape up your sound and apply room correction
If using a parametric eq, it should be a really high end one, otherwise you land up adding issues.
Even very high-quality analogue parametric EQs add:
  • Extra gain stages
  • Additional capacitors and resistors
  • Adds phase shift especially when boosting.
  • Added noise floor
  • Lesser "flow"
Typical Graphic EQ (non parametric) devices work well in vintage systems voiced with EQ in mind.
Just my opinion.
May be I will stay away from Eq for the time being to keep the chain simple. It looks like beyond my skills to tune the Eq properly. If nothing works, as last resort, I can consider. Looks like there are DACs as well with built-in PEQ.
Well, any thoughts on Gustard X26 pro delta sigma dac? Is this also just like another Topping D70 dac? Or have some flavors of R2R? Found preowned one.
Shabu
Shabu
what medium/software/source player are you using for playback?
RPI 4 with Moode Audio -> Gustard U16 DDC -> DAC(???) -> Kinki Studio EX M1+ -> Monitor Audio Gold 100 6G.
Content is mostly FLAC/WAV stored in HDD or Tidal
Shabu
Shabu
So basically you are looking for a more warmer and midcentri sound signature and hence looking to either EQ or add a tube pre etc? What DAC are you using now that makes you look to change it as that is missing mention in your chain.?
Also how are you powering the raspberry pi? I presume you are using it as a USB transport unless yiou have a specific HAT board on it
I am not sure how to describe the sound signature which I am after. Let me try to put it like this. I prefer romantic and addictive midrange, basically the vocals should have the emotional connection. This does not mean, only mid centric - should have enough topend liveness and lower end depth.
As mentioned in the beginning of the thread, i felt all those characters were present in the Metrum Jade DAC which I was using. After the failure of Metrum, I tried used Topping D70s, iFi iDSD Neo and Metrum Octave DACs but none could match the level of Metrum Jade. So I am trying to get the similar sound character of Metrum Jade with different DAC, EQ or tube preamp combo.
Yes, I use RPI 4 as a USB transport and PSU is the Allo Shanti.
Thnak you
Shabu.
