Advise tower Spks For Yamaha RX467
riteshmadhok
Hi, need to get tower speakers for my RX467, currently they power the Denon 5.1 HT which are not so very good, need some good advise on which speakers to get. My room is about 500sq feet in size.
if you are looking for just the pair, check out the following pairs
yamaha NS555
wharfedale obsidion
jamo S606
WHARFEDALE DIAMOND 10.5
yamaha NS555 - Approx 35K MRP Delhi.. Bit boomy.. did not like them.. were paired with Yamaha A-S300 when auditioned..
jamo S606 - Heard them n did not like them.. They were paired with Marantz when auditioned..
Heard good reviews about Wharfdale.. :)
What is your budget?
Will you be adding speakers later to make 5.1 or 7.1 setup?
You may audition (Prices are list prices - will get 10% disc min)
Polk Audio RTi A5 - 44k
Polk Audio RTI A7 - 54k
KEF Q700 - 70k
You can get Wharfedale 9.5, MS Carnival 6, MS Carnival 8, Yamaha 8930, Jamo 606 (after heavy negotiation or on discount from reliance digital), Mission M34i, Mission M35i.
Polk TSi300, TSi400 (I think so).
Since your room is quite BIG, I will discount all the tower speakers with anything lower than 6.5" driver, concentrate on Wharfedale 9.5, Mission M35i, Jamo 606, MS Carnival 8 and Polk TSi400.
Rest you have a good list available and auditions are your calling, time to hit the dirt track. All the best... :)
Try look for preowned/demo polk RTI A5/A7 or KEF IQ30/50 , if you like the sound of missions , m35i is the best bet. It can fill your room well.
