Air cleaners/ blowers/ compressor for home use
Mayank Shah
Madras
Hello, Anyone using any kind of compact air compressor for cleaning AV gear?. I do have a blower, but the volume of air is very high. Looking for something with a bit more concentrated pressure.
If you plan on buying an air compressor then do not buy an oiled compressor as yo will spray fine droplets of oil into your gear, buy an oil-free compressor for that
Either way compressed air will always have some small amounts of moisture in it. So see to it that you have good filters inline. Drain the tank after every use.
Best is to use a blower. if your current blower gives you too much air the buy the lightest, cheapest chinese blower in the market and that will give you less air. The blower end of a vacuum cleaner is also a good option.
