Amp advice
crowdme2
chennai
I need an amp for my revel F36 towers.
Will the Rega 2017 do them justice or is Elex-R needed?
Please advise. Any other amp within 1l worth considering?
they have a different sound signature, but both should work as your speakers are 91db well efficient
Rega Brio 2017: warm, lively, authoritative
Rega Elex-R: lean, lively, bigger sound stage
other amps to consider, but above 1L
Roksan k3: big bold sound stage, good layering through mid range
exposure 2010: fast attacking, agile, timing and rhythm
Naim 5si, etc
check what kind of singnature you like and what suits your speakers
Thx everyone for your suggestions.
@dheerajin, what speakers are you using? It looks like a unique setup. The amp is class 1, how is that compared to class ab.
@Anurag, im trying to import the Elex-R. The local price is too high. I'll contact you about the brio, if that does not pan through.
your speakers don't need any fancy amp. Just good power which the other fm's have suggested wrt pro amps.
what type of music do you listen to?
Some People with higher budget look at the price and shun the idea of buying this amp.
And some think its meant for PA application.
I think they should try it first.
