Amp for Pioneer TS-G624::plz suggest
kittu8_in2002
bangalore
I bought a Kenwood HU model KDC-U353A along with pioneer speakers TS-G624
specs for the speakers are ::
Specifications
TS-G624
Size 16cm
Max. Music Power (Nominal) 250W (40W)
Frequency Response 31 Hz to 29 kHz
Sensitivity (1 W/1 m) 90 db
Impedance 4 ?
Mounting Depth 42mm
Cut-Out Dimensions 128mm
For more details - Check Glossary
Can some one suggest a descent Amp for the same.I have a old maruti 800 , willing to spend at the max 12K. Friends please suggest. JBL,kenwood, Pioneer ????
What you have got is a coaxial speaker. Drive it directly from the HU for now. If you feel that is inadequate, then send them to rear and get component + amp to drive the front stage.
I bought a kenwood kfc-u353a ,rated 400w co-axial speakers along with a pioneer GM-6500f... its playing good, after a descent setting...kindly suggest...shall i go with some more modification
Good I have the same speakers mate on my swift and the sound from the HU(Pioneer X559UI) and this speaker is quite weak. Did this amp work for you mate ?
