Amp / Rec and Speaker (compatiblity)?
bhprin
Hi ,
How do we know which speaker is good for which Amp/Rec.. or vice-verse?
Different way of asking How do we know which Amp/Rec is compatible with which speaker.
What things(tech specs) we need to match before considering.
Bhanu
Please go through the below thread. You will get some idea.
Power matching - Speakers and Amplifiers
Generally the first thing to look for is the impedance matching. For example, if your amplifer's impedance is 8 ohms, then you should consider for the 8 ohms speakers. Second thing is the wattage in RMS. Other things like whether floor standers, bookshelves, or stand mounts depend on your budget and space available.
Hi ,
Bhanu
Hi ,
Bhanu
More important is what speaker appeals to u!!!!!!! Hear and approve the speakers. Electronics will follow too. Its not too difficult really.
Rgds
