anybody have pcb layout foramplifier using TDA1521
google gave
probably second one pcb u want i will make and give ?
Here we go I made the PCB, revision 1. ..
TDA1521 pads are created with 9pin connector pads as i dont have the lib element.
So inform me the building plan, we will do a revision of the design if needed.
I need de pcb layout of TDA1521 in stereo mode (2CH), but not with surface mount components. I want to use common components.
u can try GP board /P2P way , is the PCB needed ? Are u sure u can get the PCB done think it over.
I have the full layout..i made for RajeevMurali will share with u ..
@Kaushik: Can't we design TDA1521 on couple of breadboards? I understand for long term, we need to use surface mounts and a PCB but just for fun, is it not possible? I saw you earlier post where you have inserted a layout for it which is really great when compared with the ones found in google. So, what do you think?
