Anyone ever used the PS3 wireless keyboard ?
I bought a Bluetooth keyboard and mouse (China make). It w worked well with the ps3. Have not used the model that you have shown.
any bluetooth or 2.4 ghz based wireless keyboard should work, I am using the Amkette Wi-key touch, works well
Yes, but the one I indicated docks on to the existing Wireless Controller. That appears to be an attractive proposition and looks quite neat, although the size of the keyboard is quite small. Definitely not meant for heavy duty typing.
The Amkette you are using has the advantage of being a regular sized keyboard. So typing should be much easier on that.
Still cant make up my mind ....
Get a simple Logitech wireless keyboard+mouse combo. Connect it to the PS3 when you need it. Other times, you can use it for your desktop or laptop.
I agree with zervinb, I am doing the same too. A cheap wireless keyboard / mouse combo is what i use too
Hi, I'm using a simple USB keyboard (wired one) and it works good. It is good for game chats, but for serious browsing i will never recommend PS3.
