Audio Technica
vmscbe1974
coimbatore
Dear friends
Kindly brief me about the performance of Audio Technica PL 120 , 3 speed Direct Drive Turnable.Iam intending to buy one . If so what should be the best price?
Since this is 3 Speed DD Turntable would stereo performance be good ? Which Cartridge is best suited (like Grado, Shure , AT )which is available here.
srinivas
Hi, that's a good TT. Costs around 12-15k. There are 2 models AT-PL120 & PL 120
My TT is fitted with Audio-Technica diamond stylus, i am quite satisfied with the performance.
Check this:
Audio-Technica-PL120-Turntable
Reviews here @audioreview.com
Anil
Dear friends
srinivas
Dear MR.Anilkumar
Thanks for your input but in the net the costs are around 25k . Should i source it directly from US? Kindly guide me.
Srinivas
Dear friends
srinivas
There is no performance here. This is basically a shoddy piece of equipment that is not even engineered correctly. The geometry of the arm is off.
Do yourself a favor if you are truly looking for good vinyl playback performance.
Check out a Rega p1 or a p2 as entry level turntables properly designed to play back vinyl.
