Audio upgrade for Swift dzire
matbhuvi
I'll be getting my Swift dzire vdi shortly. I am planning to upgrade the factory audio. If i allocate 25K for this, what would be the right way to spend it?. I mostly listen only to Hindi and Tamil movie songs. I give great importance to mids (vocal), a little recessed highs and decent mid bass.
Hello matbhuvi, 25K is a decent budget. As most ICE guys have it, you can upgrade to a decent Pioneer / Kenwood Head Unit ~7k
Component Speakers in front from Morel Maximo / Focal Access/ Infinty Ref ~ 6k
Coaxials in the Back of the same brand ~ 3k
4 Channel Amp from Auditor / Infinty Ref / Kenwood ~ 8k
Wiring and Install ~ 3K
Total = 27K
However if you can increase your budget to `30k, you can also get a decent Subwoofer with enclosure like JBL S12 / Boston 12
Thank you Berryred. Is it possible to get the smooth dashboard look with after market components in Swift?
I fear you cant, any aftermarket HU cannot compete with OEM HU on integeration part with Dash. However they are miles ahead in sound Quality and Details.
If you want to retain your stock HU, just change your front and rear speakers to better ones, i am sure you ll enjoy that
My old dzire oem headunit had two preouts for connecting amplifier to default headunit itself, may not be the best sq choice but you can maintain the oem look.
I thought it is worth to bump the thread as i have further question on the update.
I have a "JVC KD-S100 Bongiovi CD Receiver ". Is this receiver is a worthy upgrade of the default player in Swift. If not, i am planning to gift this to one of my relative.
Finally ..decided on the components after overshooting my budget by many times.
It is ..
1. HAT Unity component speaker
2. Celestra FA475X amp
3. Energy ES300D sub
4. JVC KDS-100 HU
Install will be in PowerZone in the first week of Jan
It is ..
4. JVC KDS-100 HU
WoW dude, looks kick a$$. Where do you get HAT and Celestra here ? They are one of the few brands which stand out in the crowd. Excellent choice i should say.
Looking at your equipments, guess the budget would have hit the Big one. Am i right ?
There is a new startup company called BeeSound. They are the dealers for HAT and Celestra. Comp + Amp put a hole of 47K. ES300D is a used one picked for 4.5K. HU was bought for $130.
Holy !!!! 47k ? Thats phenomenal, i was expecting something around 50 k for the Amp alone !!
Can you pls share thier website / contact details. Sounds interesting.
So when is the install
Beesounds. You can contact Praveen [email protected] / 9600085160. He is a well reputed forum leader in gearheads.in forum. They have some awesome pricing. Plus they have an inaugural 10% discount. They told me that they got a pre-order for 60% of their stocks where as the first round of stock comes in 1st week of Jan.
Why not go CASAKA or WITSON OEM TYPE system with gps ,touch screen ,rear sensors ,many more ....
That is one of my plan to upgrade to a double din touchscreen HU. But, i want to take one step at a time. There are many single din HUs with great SQ and very nice preouts. I need to study a bit to understand the same on double din.
