What amp+speakers would you advice in the 30K range to compete with these? The closest I could find (for the sound that i LIKE) is a 24K marantz + 30 k wharfedale =more money than i would like to spend right now.
I havent heard bookshelves at all - i will give them a try.
So - any tips? also, what did you buy?
Ok I don't want to confuse you, sp here's how I went about it. YMMV!
Initially decided to spend around 20k, the only thing available was A5, but didn't like the warranty conditions and frequent complaints from people who have it in India about repeated failures and other issues.
After auditioning for around 3-4 months, I identified the speakers and amps that I liked. The budget came to around 75k-100k for a stereo system. Much more for a 5.1 av + fronts/center/rears/sub, so I decided to stick to 2.0 and get a sub for 2.1 in some time. Moreover I didn't like the avrs at all compared to the stereo amps when it comes to music.
My setup came to around 75k. Dali Lektor 2 Bookshelves + Marantz PM 7003 amplifier + Asus Xonar Essence STX sound card.
So my advice is:
If you have a fixed budget of <20K and are willing to compromise on the above mentioned issues, go ahead. A5's great and hopefully should last you for a few years. Just that you won't be able to reuse these when you decide to go for an avr+speakers or amp+speakers later on. For example, my AMP has a power out, so I can connect an AVR to it and drive the front speakers. ANd I can use the bookshelves that I currently have as rears and get great sounding floorstanders (like Dali Ikon 6 or MA RS6 or better ones). So I reuse everything I have!
About the 30k wharfedale, I can't say anything. I have auditioned around 10 floorstanders and I didn't like anything that cost below 55-60k. Moreover I find that in conventional flats/apartments bookshelves sound really nice. I personally hate the way the wharfedales sounded when I auditioned them last year. I would buy the Quad 11L or 12L bookshelves anyday instead of the wharfedale FS which comes at the same price.
If given a budget below 30k, I would have a hard choice since that means compromising on something or the other. I would probably get a Marantz PM5003 stereo amp and Dali Lektor 1 speakers for around 40k, or get cheaper speakers for 10-15k (search for those in the forum) to a total of 30-35k. Still that's twice the price of the A5, so if you are really particular on the budget, stick to it and get the A5!
