AUDIOPHILE SUNDAY TIP # 12: Star Wired Power: The Quiet Upgrade
Fiftyfifty
Panaji, Goa
Why one wall outlet matters:
When different components in your system draw power from different outlets, they can be on slightly different electrical grounds. This can create tiny voltage differences that manifest as ground loops, hum, or subtle noise. By plugging your entire system into one wall outlet, you ensure all components share the same reference ground, reducing the chances of noise and keeping the sound cleaner and more transparent.
Why star wiring is important:
Most power strips daisy-chain the sockets with each outlet feeding the next. This means some components share power paths, which can introduce interference or voltage drop when one device pulls current. A star-wired distribution box solves this by giving each socket its own dedicated line back to the main inlet. Each component gets a clean, equal-power path, reducing crosstalk and maintaining consistent performance.
Benefits you’ll notice:
Lower noise floor, tighter bass, and an overall sense of clarity and stability in your system. Especially with high-sensitivity speakers or revealing setups, this simple power discipline can elevate your system’s performance in a way you’ll hear immediately.
www.unboxaudio.in
P.S. We offer the full range of Furutech products, including distribution boxes, cables, connectors, and accessories, to suit every level of system. Reach us at 9764227764.
