AUDIOPHILE SUNDAY TIP # 16: WHY CARTRIDGE COMPLIANCE MATTERS
Fiftyfifty
Panaji, Goa
Right Cart. Right Arm. It's not just theory
When you mount a cartridge on a tonearm, the two form a resonant system. The goal is to ensure this system resonates in the safe zone of 8–12 Hz. Too low and footfalls, record warps, or rumble will muddy the sound. Too high and the resonance creeps into the music band, affecting bass and midrange clarity.
Resonance frequency (Hz) ≈ 159 / √( (M + m) × C )
  • M = effective mass of the tonearm (grams)
  • m = cartridge weight + mounting hardware (grams)
  • C = cartridge compliance (µm/mN)
Light vs Heavy Arms:
  • High compliance cartridges (soft suspensions, often vintage or MM types) prefer low-mass arms.
  • Low compliance cartridges (stiffer suspensions, many MC designs) need heavier arms to control them.
Special Note for Japanese Cartridges:
Japanese makers (Denon, Audio-Technica, etc.) often quote compliance at 100 Hz, not the 10 Hz used in the formula. To get the right value, multiply the spec by roughly 1.5 to 2×. Without this correction, you may think a cartridge doesn’t suit your arm when it actually does.
Bottom line: Get the matching right, and you unlock cleaner tracking, tighter bass, and more lifelike dynamics. Get it wrong, and even the best cartridge can sound underwhelming.
Watch:
Thanks for watching!
www.unboxaudio.in
Tip idea courtesy: @arj
Excellent Topic Kishore. Very often when someone feels a cart is not playing to potential, its very often dur to the mechanical resonance between the cart and tonearm !
Tonearm damping also matters but this is one of the old objective ways of cartridge Matching
@arj Tonearm damping can be tricky, nah? How much to damp and how to damp? Would be nice if you and others throw some light on this
This is such a grey area ! personally would never try it and always choose a cart for that tonearm. would be especialy worried in putting a low compliance Cartridge to a light cartridge as that can no just ruin the cart but also the record tracking issues, and uneven groove tracking.
