I have a question to the enlightened forum members.
I recently upgraded my AV receiver to a Denon 1611 which supports Dolby True HD and DTS HD. I have also upgraded my DVD player to a Philips Blue Ray player which also supports both the format. My question is does optical/coaxial cable is capable of carrying Dolby True HD or DTS HD. I did some quick search on Google and I am getting contradicting information.
Some say that to get the Dolby True HD/DTS HD I need to route the HDMI cable from the blue ray player to the AV receiver to get the HD sound, as optical/coaxial cable does not support Dolby True HD. Others are of the opinion that our ears cannot make out any difference between a regular Dolby and Dolby HD so a coaxial cable should be OK.
My preference always has been to connect all equipments directly to the TV rather than routing via the AV receiver. But as per Google search if coaxial/optical cant carry Dolby True HD then have no choice but to route it via the receiver.
Appreciate if anyone has more insights onto this and any experience using Dolby/DTS HD.
Many Thanks
Spiderman
Many Thanks
Spiderman
