AVR for Monitor Audio RX6.
capgp
Hello Friends,
I'm planning planning to buy Monitor Audio RX6 and I need your suggestion AVR suitable for the same. Budget is around 35-40K.
Thank you. :)
Is your listening going to be music most of the time? Rather get a Stereo Integrated amplifier.
+1 to taranfx. if youre going to listen to music most of the time and dont plan on going surround sound youre better off with a stereo set up. for a given budget you will get better quality music from a stereo amp rather than a avr. also i generally would spend an equal amount on the amp as i would on the speakers. for 35-40k you would hardly get an amp that would do credit to the rx6. perhaps you can think of upping your budget?
Hi capgp,
Please delete this thread as there already another thread with the same subject and there are more posts in that thread.
Hi capgp,
Hi shanmune.
Il do it right away. As I'm completely new to this forum I didn't have an idea where to post this query at first.
Hi Cpgp
which dealer in mumbai has Monitor Audio RX6 speakers ? if I can have his contact details pls. i'd love to audition these speakers.
