AVR / Processor - Pre out ratings
dudezn
Richards Bay ,South Africa
I am looking for a pre / pro or to use a AVR to drive my power amp Emotiva XPA-5.
I have settled on the integra to do the job. however I need to under better how the amp or pre/pro will be able to effective provide the correct inputs to the power amp.
I have read that the Emotiva is designed around a minimum of 1 volt as an input to effectively drive the power amp
Questions :
The difference between Integra rated outputs and maximum outputs.
How does this compare with other manufactures data of single value
outputs (Rated outputs)
Which value should I consider then looking at the integra data to see
if the output is adequate.
Would the DTR - 30.3 of 2 V/2.2 k? make a difference compared to the
DTR - 40.3 of 4.6 V/ 470 ? and how is this comparable to the DHC - 80.3
of 5.5 V/470 ohms (Pre out) and XLR 11.0 V/470 ohms (Pre out).
Integra -DTR - 30.3
Input Sensitivity and Impedance (Unbalance)
200 mV/47 k? (LINE)
Rated RCA Output Level and Impedance
200 mV/2.2 k? (REC OUT)
Maximum RCA Output Level and Impedance
2 V/2.2 k? (REC OUT)
Integra - DTR - 40.3
200 mV/47 k-? (Line)
2.5 mV/47 k-? (Phono MM)
200 mV/470 ? (Pre out)
4.6 V/470 ? (Pre out)
Integra - DHC -40.2
200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
4.6V / 470 ohms (Pre Out)
Integra - DHC -80.3
Rated XLR Output Level and Impedance
2.0 V/470 ohms (Pre out)
Maximum XLR Output Level and Impedance
Denon - 3312
Input sensitivity/Input impedance
200 mV/47 k?
Rated output:
1.2 V
Yamaha - RX A 1010
Pre out
1 \V / 1.2 K?
Thank you for your valued inputs.
Best Regards
Jerome
The XPA-5 has an input sensitivity of 1.25 volts. So what you have to look for is a pre that output more than that. Though it is not mentioned, I am guessing the XPA-5 will start clipping beyond 9 volts.
So take a look at the output of the pre's that you have listed.
(1) Integra -DTR - 30.3
2 V/2.2 kO (REC OUT)
(2) Integra - DTR - 40.3
4.6 V/470 O (Pre out)
(3) Integra - DHC -40.2
(4) Integra - DHC -80.3
(5) Denon - 3312
Rated output:
1.2 V
(6) Yamaha - RX A 1010
Pre out
1 V / 1.2 KO
Both the Denon and Yamaha are out. I would even skip the 30.2 as it is more a REC out specs rather than a pre-out. Choose between the 40.3, 40.2 and 80.3.
The higher the impedance, the less energy your amp will need to amplify. Don't worry much about that as the XPA-5 can go upto 33Kohms.
Cheeers
Cheeers
Venkat does this same logic apply to my 2 channel setup?
Presently using a Beresford Caiman dac in pre-amplifier mode connected to drectly to Emotiva upa-2 power amplifier, i plan to buy a Emotiva usp-1 dedicated preamplifier and run the dac via the fixed outputs to the pre-amp, would this give me better sound quality ?
There is no doubt that the pre-amp+power amp will sound far better unless the DAC has enough juice. In most cases, they do not.
