AVR receiver around 25K
sskcontrol
CHENNAI
I am planning to buy AV receiver less than 25K. After lot of research, I am planning to fix Yamaha HRT 3067. Will it be good choice for the following factor
1. Room size - 14*20 Ft
2. Movies 50- Music 50%
3. I compared with Denon X500. But I feel yamaha is more reliable than denon. Kindly suggest if there are any other receiver in this price range and give me your comments.:clapping:
Thanks For you help
Senthil
You can look at Pioneer AVR which is under the 25k bracket. See Hifimart link for details...
AV Receivers
If there are specific features you want in an AVR, you can look at purchasing second hand or sparingly used AVRs in the For Sale by Owner section or Hifi Ads or OLX / Quikr.
All the best.
Thanks For you help
Senthil
I think Yamaha HRT 3067 is not available with the dealers anymore. But the RX-V 375 is available for the same price which is a good model.
I thank everyone for your valuable comments. Since I am a newbie, I dont have the idea about the availability of this model. Can you please let me know if there are any other AV receivers in the similar price around 25K which will fill the sound for 14*20 Ft hall with some quality.
It would be really helpful if you share some comments.
Senthil
Since you are from chennai , if you are not concerned about warranty , you can buy pioneer 824 series from Burma Bazzar . I got a quote for 18.5 K last week . Brand new box packed one . I do not know if the model carries international warranty though . The denon x1100 was quoted at 28K . All models are 230v and do not require a step down converter
Where are you getting X1100 for 28K? I was quoted 44K for it.
As said earlier in my post the prices are from burma bazzar ( imported foreign goods road) .The products are direct import from singapore ,malaysia
