Benq GP20 Firmware
DivineSense
Scandinavia
Hi, nice to be here.
I've read a few posts about FW updates for the Benq W1070 and the likes. Looking at the file sources posted I cannot find any FW for the GP20 that I have some problems with, there is a nice update for the GP10 but nothing for the GP20. -Yet(? It's a pretty new unit)
I guess my question is, does anyone here have experience or information about updating firmware for the Benq GP10/GP20 line?
welcome to the forum @divine..
below are from page 33 . user manual GP20..
Though the password function is disabled, you need to keep the old password in hand should you ever need to re-activate the password function by entering the old password.
Firmware upgrade.Follow below procedures to upgrade firmware version.
Only an SD Card is supported for firmware update.
Do not remove the SD Card while an update is in progress.
Do not operate any buttons during the update.
Do not turn the projector off during the update.
To confirm that the firmware has been successfully updated, go to Firmware version >
Updating the firmware
1.Connect the SD card containing the latest firmware to the projector.
2. Select Settings > Advanced > Firmware Upgrade in the main menu page.
3. Select OK to begin.
4. After the firmware is updated, please turn off the projector.
5. Power on the projector and check the firmware version
for firmware info... Benq guys are on this thread.. post query here and they might be able to direct you for the download link if available..
http://www.hifivision.com/home-thea...w1070-w1250-w1080st-firmware-discussions.html
