Benq MX815ST
dej1705
zabbar
I have a benq projector mx815st when i try to power it on it starts beeping 3 times and the lamp indicator comes on everything works except the bulb, but the bulb isn't burned. Do you know what could be the problem?
HI, welcome to the forum.
I had a similar problem, got fixed by getting it serviced. The cause was dust accumulated on the DLP chip which needs to be cleaned.
Here is another thread that has the same problem.
