Best AUDIO System for HONDA BRIO
AutoGeek
I have bought the new HONDA BRIO EMT
Could you please suggest BEST AUDIO configuration for my car.
The car doesn't have much boot space. Is it possible that I can have a small subwoofer.. I can afford to spend 20K to 30K max
Any suggesttions!!!!!
First of all, did you get a head unit with the Brio, if yes, do you want to keep it or replace it? 30k is the ideal budget for a normal music system. You can go for the following upgrade:
1. Oval Speakers-5k(you'll get a decent pair)
2. Components for the front:10k
3. 4-ch amp-8k
4. SUB with enclosure-7k
Hi Autogeek,
Just an other suggestion apart from arvindrao15's suggestion --> Don't go for custom enclosures that are commercially available in the shops , better go for a custom built tuned enclosure for your taste of listening or just buy an sub and enclosure for any reputed brand.
Thank u for your reply...
As we all know BRIO rear is complete glass..Do u think keeping a Subwoofer or Bass Tube would do any sort of harm to the rear glass in long run of the vehicle I mean do I have change the glass....probably I am getting too much concerned since It's MY FIRST CAR..please ignore if I am sounding stupid....
Autogeek, you have no reason to worry. The Honda Brio comes with a high strength glass and it is as strong as a regular metal boot. Besides i think it would be better as it will rattle less!
Thanks for the reply... coud you suggest me a bass tube which should be btn 500-1000 watts. Most of the brands have 1200 watts as starting range....
JBL GTO 804, its an 800 watt 8" subwoofer.
Its not so powerfull, but will do the job decently, and for hatchback car, woofers of this size should do a good job.
