Best Bookshelves+Amp Setup for 30K
antshr
Delhi
Dear All,
This is my first post and my combined budget for BS+Amp is 30-35K.
Room size 12'x12'. 100% music. Music genre is all except death metal and country songs.
Warmth in music preferred, sound should not be bright. Large soundstage width & depth preferred. Bass should not be "too low". Fluidity in mids desirable.
Thanks. :o
PSB Alpha B1 + Nad 316BEE might just be what you need.... :)
Might cross you budget by just a little bit. I've heard many speakers in this price range and in my personal opinion the PSB Alpha B1 is the best all-rounder speaker out there...!!
Other members will give more suggestions, Do try to audition all that you can....
Welcome to HFV & Best of Luck....!!!
Marantz PM 5003 / 6003 with Wharfedale 9.2 / MS Aviano-2 will be a good combo.
N.Murali
Why not give topping tp20 and Usher's or JBL Control 1 a try, you ll save money and ll be a good option. Search Forum there is a long thread on that.
Hi I heard a Bang and oleufsen I Pod doc working yesterday and I think that it was real bang for buck at the UB Mall in Bangalore.Al;though it costs 85k and over your budget I think it is worth a try.
Pkj123
As Rana suggested you can check out NAD 315BEE paired with PSB Alpha B1 combo, this pair will cost you around 36K but will give you the ultimate satisfaction for the money spent. You can demo this combo at our Lajpat Nagar 2 showroom in Delhi.
Ashish
You can pair a pair of quad 11l2 with a used marantz amp( there's one on sale in our classifieds). It will give you the fluid mids you are looking for without excessive bright treble.
Else the Nad-Psb combo is a good option.
i would advice the Quad 11L2 and a warmer amp like a Denon
another one of my favorites is a KEF IQ10/30 and a Denon or even a NAD-
if you can hold of the older monitor audio
BR2 and a NAD- that would be an all time favorite too
NAD PSB is a good combination but these speakers are either loved or hated , rarely in between - so dont buy without a listen
P.S : one of my setups feature a NAD PSB (PSB image series and a 325NAD )- hence the advice
however i think all options will cost you about 40k and up so be prepared
(unless you are looking at PSB alpha B1 and a NAD 315 )
i have heard all the above combinations more than on one occasion each as far as i remeber- they are all super
