Best HOME THEATRE for UA55B8000
silverghost
Mumbai, India
I stay in Mumbai and just bought a new Samsung 55 inch LED tv for my bedroom. Now all I need is a decent HT system to go with it, but I just cant figure out which one to get. I dont wanna spend more than Rs.30,000.
i checked out the Sony DAV-DZ510 since it has optical in which will be helpful for my PS3 and PC optical out TOSLINK.
DAV-DZ510 : DVD Home Theatre System : Home Theatre System : Sony India
I knowledge is very limited when it comes to these things, so could someone suggest a HT system (5.1) for me. The rms doesnt need to be really high coz I use this in a bedroom But I need excellent depth and surround. Any company is good. Im willing to up my budget if the system is really worth it.
Alternatively, would I have any problem using a Sony HT system for my Samsung LED tv, considering both are rivals, where in they might not make themselves compatible to one another.
Please advice
It is difficult to get a full blown HT for 30,000. Best option for you would be to look for a HTiB. Popular options are Onkyo and Philips.
