Best Performence Setup - Boston Acoustics A26 : Wall Mount/Stand or??
balzac
India
Hi All,
Which is the best way to get the full potential of Boston Acoustics A26 speakers?
Should it be wall mounted or on a Speaker Stand? (suggest a product too, if possible )
What should be the height from ground level at which it should be placed for best performance?
Also, for all the BA A26 owners, how have you placed your speakers?
All suggestions are much appreciated.
Cheers!!!
Hi All,
Try different possible options.. The speakers are rear ported, wall mount it.. See if the bass gets boomy.. Easy experiment is to put it on plastic chairs and give some space from rear wall and observe the difference..
Should it be wall mounted or on a Speaker Stand? (suggest a product too, if possible)
Speaker stand might be the best... Magma stands on hifimart..
What should be the height from ground level at which it should be placed for best performance? All suggestions are much appreciated. Cheers!!!
Tweeters at ear height.. Roughly 36 - 37 inch high is where the tweeters should be..
