Best picture setting for Sony 43x75k
Ryzen
Kolkata
Recently bought Sony 43x75k. I am using it as a monitor as well as tv for OTT apps. What is the best possible picture setting for monitor use and tv? Can anyone please guide me.
Standard setting was very accurate in Sony x75. For monitor use its the best. Dark scene performance of the x75 was not great, I used to turn TV to vivid mode during dark scenes. I think you can try the same watching movies with darker tone like the new Batman or Venom.
The best settings depends on individual taste. Some likes the images more bright and more color vibrant some likes moderate brightness and less color vibrant .
I have Samsung TV, I mostly adjust brightness -60% , backlight:50%, sharpness:60%, color vibrant: 65% settings ..etc.
I set "Dynamic Contrast" to low which increases the black levels.
I set White Balance points to 50% which balance the black levels.
Gamma correction to 1 or 2 points, mostly 0. (set to high if you see more black levels, even after adjusting white balance)
I think your tv will have similar settings and u may play around these and get the best picture as per your likings.
