Book Shelf Speaker Review to avoid ambiguity in choosing speakers
Cnu
Mehsana
under blind conditions, with level matching employed between each pair of speakers for switching purposes.
The SVS SCS-01 pair was characterized as follows ...
1. Depth of soundstage is excellent.
2. Microdynamics (subtle clues are more easily discerned. As an example, there some sea-gulls in the Roger Waters SACD "In The Flesh", the SC-01 plays them very clearly).
3. Reproduction of vocals - both male and female was excellent
4. Percussive instruments are very accurate, while brass instruments lacked a bit in the immediacy of the live instrument.
5. Width of soundstage is limited to inside the speakers.
6. Bass was very good, as long as an 80 Hz crossover was used.
The PSB Image B-25 pair was characterized as follows ...
1. Depth of soundstage was quite good.
2. The width of the soundstage was wider than the speakers, but not quite in the league of the Ascends.
3. Microdynamics were as good as the SVS, with subtle clues coming through clearly.
4. Vocals were excellent, including male and female. with a bit more "smooth" a presentation.
5. Percussive instruments were very good, as were brass instruments. Live guitar was not quite as well done, but was good... just a little "soft".
6. Bass was quite good, and a 60 Hz crossover can be used.
The NHT Classic 2 pair was characterized as follows ...
1. Depth and Width of soundstage was better than any of the other speakers.
2. Microdynamics were outstanding, and again, superior to the other contestants.
3. Macrodynamics were lacking. We were using the Emotiva LPA-1 for all the speakers here, which is substantial power. The NHT's just don't like "going loud".
4. Within their limits, vocals, brass, percussive instruments, and guitar were all presented with excellent results.
5. Bass was pretty good, but with dynamics limited. For Home theater, a 100 Hz crossover is recommended.
The AV123 X-LS pair was characterized as follows ...
1. Depth and width of soundstage was very close to that of the PSB's ... very good on both, with just a bit more depth.
2. Microdynamics were excellent, not quite matching the NHT's, but on about a par with the SVS SC-01's.
3. Macrodynamics were a bit behind the PSB's, with almost the same amount of ability to "crank".
4. Vocals were outstanding, with a smooth presentation of both male and female vocals.
5. Percussive instrument presentation was the best of the group, while brass instruments and guitar was very good. Guitar was a little soft.
6. Bass was excellent, with a 60 Hz crossover easily handled.
The Elemental Designs A6-5T5 MTM speakers were characterized as follows ...
1. Depth and width fairly shallow and narrow compared to the more expensive speakers.
2. Microdynamics were very good - almost matching the X-LS.
3. Macrodynamics were excellent - almost matching the PSB's.
4. Vocals were very good - a slight stridency in female vocals compared to the more expensive stuff, but for $200, very slight.
5. Percussive instruments were excellent - lots of snap to a snare drum, and brass instruments were very good. Again, the more expensive speakers were better, but the eD's were better than expected for $200.
6. Bass was quite limited, with a 100 Hz crossover recommended.
The Dana Audio model 630 speaker pair were characterized as follows:
1. Depth and width were a match for the best in the test yet. They slightly bested the NHT's in both arenas.
2. Microdynamics were excellent - again a close match for the NHT's.
3. Macrodynamics were about on a par with the PSB's, and was excellent.
4. Vocals were also at the top of all the bookshelf designs ... Tony Bennett's duet with KD Lang on his MTV SACD is outstanding.
5. Percussive instruments were handled with ease, lots of snap to the snare drum, and brass instruments were outstanding in presense.
6. Bass extension was quite limited, with a 100 Hz crossover recommended.
Acculine A1/A2
1. Depth and width were excellent on both loudspeakers, and among the best in the test.
2. Microdynamics were excellent, one of the best in the test.
3. Macrodynamics were quite good, but not at the top of the list.
4. Female vocals were excellent, while male vocals were slightly "weak".
5. Brass instruments were very good, and percussion quite accurate, but not quite as dynamic as the best.
__________________
You mentioned some interesting stuff, good that you got to hear all this
how did you level match?
i have read many in forums...and try to collect them all at one place..so that people can easily find at one place...
Cnu!!!!!I wasted my time to read this..It is only my fault,,,, I could have seen the Panditji prediction first and could have gone to the first post..Mods!! the right thing is to paste the panditji finding in first line....
Why not members write clearly in the first sight before copying the contents.. Thought it was an audition and later it was only an edition..
However appreciate you have time to compile it, kindly endorse the writing before going ahead.
are all these reviews lifted from one place ?
or how you can explain "under blind conditions, with level matching employed between each pair of speakers for switching purposes. "??
i think the OP has done us all a favor by putting all the reviews under the umbrella of one thread....as that old adage goes ..we should concern ourselves more with the fruit than counting the trees..and anyway it has been acknowledged that the effort has been towards putting it so that "people can easily find at one place"...
unless there is a devious commercial motive we should all be willing to give our friends the benefit of doubt as far as motives are concerned...
^^I agree with Moktan,the OP has done a noble thing and tried to help us by providing short reviews of various speakers that he came across the web...there is absolutely nothing wrong with it and we should appreciate it rather than filling the thread with sarcasm.Actually, its these very reviews that we also run around to read before an audition.The only minor flaw IMHO was not providing the source but i think he would correct it soon.
Good job,Cnu...much appreciated.
Yep, thats what I feel too, nothing wrong in compiling reviews at one place, but give the original source due credit.
Sorry for the sarcasm......My apologies to Cnu but most of those speaker brands are not available in India so no point putting a comparison on this forum...
It is like Hemant comparing Katrina v/s Drew Barrymore v/s Kate Moss for all of us here incase someone decides to date any one of them... We audiocrazy people have no chance in hell of dating any one of the above so no point in comparing them...
