Book Shelf Speaker
TNR
Hi Folks,
I am looking for a pair of book shelf speakers which will be powered by Yamaha RXV 450 amp. The max i can push is 15 to 17 K for a pair of speakers.
Music type - Unplugged / R&B / Soul
Volume preference - Normal to low than normal
Size of Room - 6*8*11(l*b*h). In case you are wondering yes the roof is 11 feet old time structure. Receiver placed in Corner and i have room for just 2 book shelf speaker. In my budget are there a speaker available? Please let me know.
Thanks in advance,
TNR
Hi All,
Yesterday i check out Bose 301, Wharfdale 9.1 / 9.2/ 10.1 and Jamo.
Bose 301 - Had a good thump decent midrange clarity and little sorround effect because of their direct reflecting tech.
Wharfdale 901 - Cost 12k clear mid range but low on low frequency
Wharfdale 901 - Cost around 17k good crisp mid range and slighty better low frequncy.
I am novice so i am guessing thats why diamond 9.1 and Jamo C series sounded the same. Also bose was driven by Denon amp, Wharfdale driven by basic custom built amp in straight mode.
I am keen on wharfdale 9.2, any better options that i should i try for 17k?
There are many choices between 15 - 20k budget.. Do take your time to audition as many as you can and buy.... Do not rush.....
Some more list you can audition :
Tannoy F1
MS AVINO -2
PSB Alpha / Image bookshelf
Paradigm Atom/Titan monitors
Usher S520
try mordaunt short aviano 2 @ 19k!.supposedly too good!.and wats with the two wharf 901 priced differently?!!!901??????????
TNR,
The King of Bookshelves in that price range IMHO is the PSB Alpha B1....!!!
I ve not come across any bookshelf speaker in that price range which has got more rave reviews, recommendations, & best buy suggestions than the B1.
I've heard pretty much every speaker out there in that price range and the B1 will cream all the other speakers. Again that's my personal opinion.
Go and hear them out... Your dilemma will be over in 10-15 mins...!!!
Best of luck.... :)
Hi All,
Has any cheked the price of Wharfdale diamond 9.2 cost in bangalore is ? I visited Vector system on Brigade road where the quote was 17K but else where in a thread on this side it read it as 15K all inclusive, any help much appricated
TNR
Hi All,
TNR
That must be MRP/ first talk price.. Bargain you can get it for 14.5k or even lesser.... :)
Hi All,
TNR
Hi... I am 100% sure that 17K is the MRP. Generally 10% discount is given by most of the dealers. So, 17 less 10% is 15.3K. You will get it for 15K for sure. In case if you are not getting it for 15K, please send me a PM. I'll help you out.
The 9.2s are very good bookshelf speakers. It's a 100% Value-for-money speakers. The performance of 9.2s are pretty decent across all the three frequencies (higi-mid-low). In case if you need a little more depth & punch on the lows' later on add a SW-150 subwoofer to these speakers ... A great combo :)
Hi Folks,
Thanks in advance,
TNR
hi TNR-
there is a loudspeaker near that budget made in Bangalore -
send a personal message to sushanthace (member of this forum) for his impressions about this speaker
Hmm, sounds mysterious:rolleyes:
hi captrajesh -
yes, -
after sushanthace has finished listening to these loudspeakers - i will ask him to give them to you for evaluation -
and there will be value in your opinion for me ( just as sushanthace's opinion will be a learning process for me)
regds suri
Hi Suri,
That would be really wonderful.:licklips:
Donno if I can contribute any but sure it would be a learning process to me.:)
