Bookshelf speaker within 40K to pair with NAD C372
krishnenduk
Kottayam, Kerala
Hii,
I am currently using Wharf 9.5 mated with onkyo SR705 receiver for music as well as movie purposes.. Recently i bought a NAD C 372 integrated amp.. Its a 150W/channel amp..
C 372 Stereo Integrated Amplifier - NAD Electronics
Now searching for a BS speaker within a budget of maximum 40K purely for music to pair with it.. I usually listen regional music, some pop, some trance and some rock.. My room size is approximately length X width x height = 22 X 11 X 15 feet.. Hope a BS will suffice.. pls give some suggestions..
Thanks and regards... :)
That's a big room you have there, recommended Speakers would be towers or largish Bookshelf Speakers. Try pairing the NAD with PSB speakers, specially Image B6 and Imagine B, as both NAD and PSB are sister concern company so their pairing goes really well.
But if budget permits look at ma GS10. I have heard it with my nad and sound sweet. 372 has good power , so you can look at bit higher end speakers imho
then psb b6 @ 27 K or b&w 685 @ 40 k are good options.
i have the b6 and with the recently aquired nad 2400 power amp they are sounding really really nice. Do carry your amp for audition.
Bro..
I am from Kerala.... Hope of auditions are very less here.. So have to go with the expert's suggestions from here... :)
Got an offer for Paradigm titan Monitor and Dali ikon2 (not mk2).. Dont know how well they sound with NAD..
for my room size, length X width x height = 22 X 11 X 15 feet, does the BS will suffice?? or do i need to look for floorstanders??
