Bookshelf Speakers to pair with Onkyo HTS-22HDX
gilagamesh
Hi Guys. I am planning to buy bookshelf speakers for my Onkyo Hts-22hdx. My budget is 15K INR. I have shortlisted this 2 ones - Cambridge Audio Minx XL Bookshelf Speakers (14K) and Q Acoustics 2010 Compact Bookshelf Speaker (15K). Among these two which one is good. Also if suggest if there are good ones besides these under 15k. I am inclined towards Cambridge because its 8 ohms and the receiver can easily drive it (QA is 6 ohms).
Please provide your comments or advice regarding the same.
Cambridge Audio Minx seems to have good reviews. Where are you going to buy it in Bangalore? Or will you be trying from Hifimart ? Personally I wanted to know if there are dealers in Bangalore where I can go and check out how it sounds.
Sir, I am planing to buy Good Stereo Amplifier and Bookshelf Speaker. My Budget is 30k. I have shortlisted Bookshelf Speaker ELAC BS 53 price is around 16.5k. I am confused with suitable amplifier my option is Sonodyne SIA 310 and Yamaha R S 201. I need FM Tuner with integrated Amplifier. Kindly advice what is my best option.
