Broadlink RM2 Pro or any other Universal RF & IR combined remote
rdksrk2013
I am on the lookout for a universal remote which will have combined IR & RF functions to operate audio systems + Remote curtains + Air Conditioners+ LED lights.
Does any member have experience with Broadlink RM2 Pro which declares that it is capable of controlling IR or RF devices through WiFi ?
I did not read positive reviews on the Broadlink Pro. Particularly it does not have the database of different makes facility convenience as in a Harmony remote and it is ridiculously unstable operation.
Does anyone have a positive feedback on Broadlink RM2 Pro or any suggestion on alternative brand ?
Thanks in advance.
If you can source one, the Harmony Hub with the basic remote is really really good
Does the Hub with remote have RF + IR ?
RF can use multiple frequencies/standards - any specific standard you are looking for?
FWIW, the physical remote is a RF remote and does not need line of sight
In addition to the remote, you can use your android/ios phone as a remote
The hub can control IR devices (obviously) + can act as a BT remote (e.g. text input on TV) + can control various wifi controlled devices (e.g. wifi light bulbs)
Thanks Superczar for the info.
So I can confidently go for this combination.
The RF req for operating some devices is 433 MHz. Can this operate at this RF frequency ?
Do you have one ?
How much this combo cost ?
