BS for yamaha 371
Shashant
Delhi
Hi Guys,
Recently got Yamaha RX371 and now looking for a BS pair.
Budget is 20K (less is better :p)
I have WD 9.2 and Monitor Audio M2 in mind. Are they good match to 371?
Please suggest.
Shant
Yes, they should match well, you should try out WD 10.1 and 10.2 as well, they are much better than 9.2o or MS Aviano 1 and 2.
Then there are PSB Alpha and Image BS as well.
Thanks imgene.
Whats the price for PSB Alpha
The Q acoustics 2020 available in our Group Buy is also a good option. I have not heard them so cant comment much. Wharfs are great buy for your budget. 10.1 should come around 17k I believe.
Hi guys,
Just bought WF 9.2 for my yamaha 371. Source is Philps DP as of now.
However sound is not very detailed at low volume.. Not sure its the right match.
I 've been offered by dealer to check out Monitor Audio M2, BR1 and 10.1 as well.. i can replace 9.2 with any of them....
What you guys suggest among M2, BR1 and 10.1. I listen mostly to hindi, instrumental, soft rock music.
Shashant
Sashant, WD 10.1 is anyday better than 9.2, I had auditioned both of them.
I would have suggested MS Aviano 2 as well, please audition multiple options before buying.
Thanks imegene.
Did you auditon the 10.2 as well. how they compare with 9.2.
