Upgrading Speakers Only - Yamaha YHT 299
zzzeharzzzehar
Delhi NCR
Hello Friends, just found out about this amazing forum! I am in a bit of a dilemma and need advice.
I currently have a Yamaha YHT 299 5.1 Home Theater in a Box package, it comes with NS-B20 fronts and surround speakers and NS-C20 center channel. The subwoofer is NS-SW20. The AVR is HTR-3066 that came along with the package.
I am looking to upgrade the speakers and subwoofer and inclined to buy used. My budget is max of Rs 35000 (+/-10%). I am okay with keeping my existing sub for sometime and upgrade gradually if I cannot manage it within the current budget but I'd prefer to get fronts and center channel and if not lastly, just the fronts for now and upgrade center and sub later. I have shortlisted the following options; I am leaning towards floor standing speakers but would love options on bookshelf speakers that are significantly better than these floor standing speakers.
  1. Taga Harmony TAV 507 5.0
  2. Mission M74 - just the front pair
  3. Denon SC-A55XG bookshelf
I am looking to get the max bang for buck but most importantly, a significant upgrade over my current system. I am okay with selling my entire YHT 299 and upgrading the whole things as well if I can manage within the increased budget. Pls suggest! I will continue using the same AVR for now i.e. HTR 3066.
For speakers, I would recommend ELAC Debut 5.2 or DALI Oberon 1. But before upgrading anything, plan the entire upgrade path for the future first. So that you won't do unnecessary spendings and regret.
I began in the same way with the same Yamaha speaker set but with different AVR in 2015/16, now have replaced everything excluding the centre and surrounds, because I was more inclined to better stereo/music listening sessions than HT. Hard learned from the experience and multiple wrong buying/selling that AVR is not the best for music, floorstanders are hard to tame- requires bigger rooms and space from back walls AND in the same budget bookshelfs produces much better sound. So in short, it is not about upgrading the components, but knowing your exact fondness and set a vision, and do the upgrades as per the vision. Now my entire stuffs are around 2.25L and quite satisfactory to my requirements.
