Budget HT upgrade - Need advice
X man
Trying to upgrade my HT speaker system ( budget) - Considering Wharfedale 10.1 set up. But recent what hi fi have given a good feedback on Tannoy as well. Any advice will be very helpful.
Depends on your budget, but the Tannoys sounded better than the Wharfedales to my ear.
You can consider q acoustics 2000 cinema. They have released an upgrade to this model and the old one should be available at bargain prices.
-Ajay
My exp in the last Mumbai meet suggests that you should try & audition some of the Indian brands before making a decision... A 15k pulz speaker brought to the hifi meet in Mumbai sounded way way better than the wharf or the tannoy (both 17k+)... If you are looking for best bang for buck then my humble view is Indian speakers is the way to go...
