abhinav
Hi folks,
Have been lurking around and asking questions here and there, but decided to start a separate thread so as to not hijack others'
Background :
* Noob when it comes to music equipment, starting from scratch.
* Want a system primarily for Music, but would like to connect to PC/DVD/TV so that I get better audio quality (currently PC/TV have stock speakers etc, so any thing will probably sound very good).
* Music source - currently none, planning to buy Audio CDs and converting to FLAC - so I should be able to play via the computer as well as a CD player (have a philips DVD/CD player to start with). Not planning on getting another source, but this needs to be considered prob in AMP suggestion.
Thoughts
* Would like to go for an Amp + 2 speakers now, and get the others over time. Willing to change this model if required
* Looking for VFM deals at low/mid end, available locally
* Planning to spend around 12-15k for the AMP, and another 10-12k for speakers. Is this enough to start with ? Lower is always better
Would like to keep it within 25k if possible, 30k max.
* Upgradeability to a 2.1 or higher would be a good thing, so that the PC/TV/DVD quality can improve over time
* Types of music - Film, Ghazal, instru etc, nothing very hard rock type, primarily at low volume
* Room size - around 12x8
Could folks suggest where to start ? Amp or Speaker, and which ones ?
I almost decided on Topping TP20, but it doesn't have multiple sources etc. But still, am willing to consider it if I can pair it with some speakers, that can be reused nicely once I upgrade.
Also, what places in Bangalore would be good to try out these *budget* amps/speakers ? I see few names being mentioned, but don't want to get into a high end place when I have no intention of buying one !
Any other advice is welcome.
Currently considering :
* Norge 1000 (10k ?) . Reasons : looks to fit budget and requirements.
* What is a good place to audition and buy ?
* What are some upgradeable VFM speakers (for around 10-12 k) to go with this ?
* Alternatives to Norge 1000 in similar or bit higher price range ?
Background :
Thoughts
