Can I connect both usb drive and sound system to my samsung tv via a USB hub
Vikash85
India
Hello,
I have a samsung led tv which doesn't have audio out but it has a usb 2.0 port. So will it work if connect my usb drive and a usb to AV cable through usb hub to enable pen drive and speaker system to work simultaneously?
Pls help.
Do you mean to play a video from usb drive and simultaneously take out the audio from same usb port? I don't think that is possible.
Moreover, usb ports in TV are not for audio out. They are for playing files.
Your TV must be having some audio out like RCA or 3.5 mm. Share your model number so that FMs can look into it
Sent from my ONEPLUS A3003 using Tapatalk
TV Model: Samsung UA32EH4003R
