Canton 80cx or Bose Acoustimass 10 series IV
needadvice
Hope you are doing great. It would be a great help to me if you can give me your expert advice on the following:
I have a Denon AV receiver which is AVR - 390. Specification are as follows:
AVR-390
Power amplifier section FM section
Rated output *THD figures are power amp stage values. Tuning frequency range 87.5 - 108.0 MHz
Front L/R 100 W + 100 W
(6 ohms, 1 kHz, THD 0.7%)
125 W + 125 W AM section
(6 ohms, 1 kHz, THD 10%) Tuning frequency range 522 - 1611 kHz
Centre 100 W
125 W General
(6 ohms, 1 kHz, THD 10%) Power supply AC 230 V, 50 Hz
Surround L/R 100 W + 100 W Power consumption 300 W (Standby 0.8 W)
(6 ohms, 1 kHz, THD 0.7%) Dimensions (W x H x D) 440 x 141 x 377 mm
125 W + 125 W Weight 8.9 kg
Iam using Canton 80cx 5.1 speakers with this. Its Specifications are as follows:Canton Movie 80 CX specs (Meet Gadget)
Now iam planning to buy Bose Acoustimass 10 Series IV, 5.1 speakers.
Please suggest will it be worth and make sense in upgrading to Bose Acostimass 10 Series IV. Specifications are as follows:
Bose Acoustimass 10 Series IV specs
I shall be very obliged to get your advice as it will help me spend wisely.
In this forum Bose is not raved about.And I read many good things about canton..so IMHO it will be DEGRADATION!!!
If possible try to upgrade sub woofer with least 10 inches. To find matching sub take help of forum ...
What is your budget? Are you planning to sell cantons? at what price?
Also you have any space contraint so that you are looking for small seakers?
As there are packages with 4 Bookshelf speakers ,1 Centre and Decently sized subwoofer ( 10-12 Inch) which sounds far better definatly than bose.If you choose front 2 floor stands the sound will be in different league.
AVR-390
Centre 100 W
125 W General
what is your reason for upgrading? Specifically, what in the music/ sound do think you are missing in the current setup?
a hemant said, possibly you find the bass inadequate, and there a sub upgrade would be the most obvious choice.
if you do decide to look at an they 5.1 compact package, do give the paradigm cinema series a listen!
If you are after the best sound for the buck, suggest you ignore the Bose. If you have aesthetics on top of your list, then you may consider them.
Hi All,
Thanks for your comments and advice.
Can some one also please let me know the difference in technical specifications for both.
Bose doesn't reveal its technical specifications.
However, at Bose's price point, many other much better things are always available.
So you can knock Bose out of your list.
Assuming that you want to spend about 50-70k+ only on the speakers, you can get a good setup, better than most satellite setups.
Don't go for a HTiB. Go for Wharf 9.2 + 9.1 + Center + SW150
