Intending to upgrade car infotainment sys. Unfortunately, brands./models commonplace in HTS aren't as common in Car Infotainment !
Mentioned hereunder are 5-6 products planning to buy/upgrade.
A) Head Unit:
1. Hi-Res Certified
2. PQ: 4K or least 1080P (don't understand why most have pathetic resolution)
3. Built-in Amp/DSP to drive Speakers (mentioned below). Might add external later
4. Support 360 Degree Cam. Screen should allow touch/rotate over same
5. 9-10 inches diagonal
6.Shortlisted: Caska (among Android). Would prefer Non-Androids though (like Sony/Pioneer/Nakamichi)
7. Budget: Rs 35-40K
B)Speakers
1. Hi -Res Certified
2. 2 Way Components (Front), Coaxial (Rear)
3. Should be upgradeable to 3-Way config later
4. Shortlisted: Sony ES, JL Audio (C series), Harmon Kardon (Flow Series), Morel Maximo 6 MK2
5. Budget: Rs 50K
C) 360 Degree Cam:
1. Compatible with Head-Unit
2. Min 1080P Resolution
3. Budget: Rs 15-20K
D) DashCam:
1. Resolution: 4K/1080P, Loop Recording, GPS Enabled, Accessible via Mobile
2. Budget: Rs 15K
E) Ambient Light:
1. simple, nothing too fancy.
2. 4-6 piece
3. Budget: Rs 5K
F) Damping Sheets:
1. Not sure which brand to go with, and budget.
2. Something which works well for intended purpose.
Suggestions on any/all products mentioned above are welcome! Will pull the trigger in next week or so.
Appreciate your help & guidance.
Thanks!
A) Head Unit:
1. Hi-Res Certified
B)Speakers
5. Budget: Rs 50K
C) 360 Degree Cam:
D) DashCam:
2. Budget: Rs 15K
E) Ambient Light:
2. 4-6 piece
3. Budget: Rs 5K
F) Damping Sheets:
Thanks!
