CD transport
Shivam
Uttarakhand
Has anyone here used or heard-
Little dot CD transport or Musical Fidelity CD-T ?
How do compare with inexpensive DVD/CD players as transports ?
Anyone here who uses any exclusive CD transport ?
i have for the last 6 years and prefer them greatly over any usual DVD player and most CD players.
If you want to play CDs with a DAC, get a dedicated CDT or a computer transport
DVDPs are compromised in their transport mechanism, vibration isolation, power supply and the SPDIF output when compared to any decent CDP/CDT
Which transport are you using?
Edit : reading about your transport now.
SShln1
I have been using a TEAC Reference H600 as my CD transport since the last one and a half years. I prefer the sound quality of its spdif output compared to that of the essence stx in my PC transport.
Any dealers where I can audition transports and compare them to the inexpensive transport (dvd player via digital out) that I am using? I have been told that upgrading my transport will help but I want to listen before spending any money.
Have you tried entry level CD players? I used to have a Marantz CD6003. Just for a lark, I DIY-ed an S/PDIF coaxial cable and used the CD6003 as transport. It sounded quite good to my ears. The transport I compared to is a music PC that uses a sound card which is probably 2x the cost of the CD6003. But I must admit I have never tried the S/PDIF output of the sound card (AES/EBU used). Also, the DIY-ed S/PDIF cable is a very high grade coaxial cable rated to carry full HD, uncompressed bit rate of 3 Gbps in a video post production environment. Yes, it is a video cable of 75 Ohms characteristic impedance. The RCAs are REANs. I understand that some cable naysayers may be angered by this, but I would still like to write about it because a cable rated to carry regular IF signal (circa @ 75 MHz, and may be 30-50 Mbps throughput) is not the same as a similar cable rated to have a throughput of 3 Gbps.
I have read that vintage Marantz CD players like the CD63 have excellent transport. May be you should hunt it down. Or try something modern like a CD5003/4 or CD6003/4. Or try a Shigaclone if you can find it.
I use CA 640C V2 as a transport and it is marginally better than my HTPC.
It uses a very good Sony servo disc mechanism.
I prefer its coaxial than optical out.
the vintage CD 63 was great because it allowed itself to Modding very easily. the simplest results were available by damping the overall case with Caulk /cork and the underside of the tray with Blutac.
later on the clock and Op amp upgrades took it to a new level.
the newer ones are not so amenable i believe.
Shivam,
The AP Transport is a serious transport. Siva also uses the CD-PRO2 module.
Couple it with the AP DAC and you will be set.
Regards.
The only two good transports currently in production are Teac/Esoteric VRDS and the transport from the Austrian company Stream Unlimited. In most boutique CD players you'll find either of the two. There are still a lot of NOS Philips CD Pro2 kits out in the open so many players have that as well. However they are terribly expensive.
Basically choose a well implemented version of either of these and you'll have a fine disc spinner. Everything else in the market is basically trash.
I use a Technics SL-P999 player with both TOSlink and Analog (RCA) Audio out. The tray eject mechanism and spindle motor electronics are prone to problems with age, but the laser pickup (SOAD-70A) is generally bulletproof and never skips, thanks to its linear-motor (*not* stepper motor worm-drive) driven sled, and linear sliding potentiometer-based sled-position sensor (it's still finicky in dusty conditions, but can easily be disassembled and cleaned).
The only issue is that spare SOAD-70A pickups are unobtainium new (Matsushita discontinued it over a decade ago), so the only source now is to buy reconditioned ones off EBay, where prices are in the stratosphere. Luckily, some low-end Technics CD players (like the SL-PJ27) also used the SOAD-70A, so there will be supply for some more years from the used market.
On a related note, does anybody have a reliable source for the Technics AN8377N motor-driver IC, preferably in Chennai? Mine is running fine now, but since it's a potential future source of failure, I'd prefer to stockpile a few spares now, rather than later when I might need it. It's widely used in a large number of transports from Matsushita, usually as the spindle- and sled-motor driver.
