Checking used-hours on Vu 55" 4K TV & typical settings for good picture
driverace
Pune
I have just purchased the Vu 55" 4K TV - LTDN55XT780XWAU3D_HDR from Flipkart.
Initial impressions are good.
out of box PQ is satisfactory & I am sure with a bit of tweaking, it should be acceptable.
  1. Can anyone share engineering/service code to check "total usage hours" to make sure the TV isn't used?
  2. Starting out with Hisense 55H8C 55" TV settings - of which this TV is rebranded version of -
Picture Mode Theater Brightness 52
Contrast 40
Color 42-46
Local Dim On
Backlight 40
This was at night Up to You
Tint 0 Sharpness 4
Ultra Smooth Off Noise Off
Adaptaptive Con Off
Color Temp Standard
White Balance Offsets R-3 G0 B4
Gain R-2 G0 B5 10
Point Level 10% R0 G2 B6 20% R0 G1 B1 30% R0 G1 B0 40% R0 G0 B2 90% R2 G1 B3 100% R4 G4 B6
Color Tuner Hue Sat Bright All Zero on all Colors Except for
Flesh Tones Saturation -4
I will run a few checks for bleeding/ghosting etc today.
thank you,
Ace.
