Chord Carnival Silver Screen, Crimson VEE 3 and Monster 200i
Shyamtanu
Pune
Recently bought these for my Quads, simply amazing! I did not believe that it can really improve the sound but the clarity has gone up and noise have disappeared. Earlier one was DAC 14AWG, I use banana plugs, one advice, it may be worth plugging the holes behind the plug with cotton, put some silica gel beeds inside (2-3) it will help in preventing accumulation of moisture and oxidation. In Indian climate condition, bare wire will not help much in my view.
The interconnect is good, almost as good as the monster 200i that I have been using since a year, the contact point quality in Monster is better IMO, fit is better.
My earlier audioquest sidewinder has become loose in 2 years! I did not do anything to influence that is all I can say, I had to manually press the outer shell with a players very careully with fabric wrapping to ensure the geometry does not change, tough job and should not really try unless you are sure. I am retiring this one.
Hi Shyamtanu,
I also purchased the cable chord silver screen two days back but was a little disappointed in the first listening. I think I might have to wait for the burn-in.
Would be good if you can share your initial experience, as to how you found it initially. Thanks.
Got it online from Profx. They couriered to Pune from their Mumbai store.
