rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,678
- Points
- 113
Only with BNC you get true 75 ohmsI believe a 75 Ohm Coaxial Cable with BNC connectors is much suited for the this purpose.
That's what I have been told by many
Yes it is I would prefer BNC over RCA connectors for Digital Coaxial any day, going by the technicalities atleast.Only with BNC you get true 75 ohms
In the past most of my transports had optical out, and when i compare them back to back with each other, every optical transport sounds different than the other, my understanding is that the way the circuit is implemented either coaxial or optical matters a lot.
The implementation in your DAC should be considered as well, ideally the transport outputs a signal that is being processed by the DAC.
There are sound quality changes between optical and coaxial, but i would prefer one that best suits my ear.
Sometimes I prefer the optical and sometimes the coaxial as well.
Optical cables when i used them in the chain, I felt the lows to be much better, but coaxial was much suited to my ears, a tad bit more cleaner and smoother as well.
You could try to find another transport that has optical out and compare it to your current transport as well.
i have a cambridge cxn i tried connecting them with usb to mac and via lan.
lan sounded better than usb or even the coax.
dont know why.
and i also had an improvement in sound when i changed the cable to a cat 6.
anyone care to explain y is this so.
shouldnt the usb or the coax sound better ?
usb cable i used was from audioquest. coax was from kimber while the lan both cat 5 and 6 are local brands.
already ordered a cat 7. i though coax has the shortest signal path than RJ45 !Spdif uses multiplexing to send data over fiber or copper. So the implementation has its own challenges.
In LAN it's directly streamed. Cat 5 is thinner and has less twists compared to Cat6. Try cat 6A and cat 7.
Arj, this could be because of external factors. In the past I read somewhere that optical transmission is immune to external rf or emi, etc. Coax transmission gets affected. Which is why you could be hearing the differences. Generally the hash can result in a digital sound with a feel of more separation. Also when using coax, the transients can get blunted resulting in a more acceptable sound, especially if the recording is compressed.
I remember reading that it depends on the Optical converting unit they use. eg at the lowest segment of cheap DVDps the Optical is better since the cheapest converter outperforms the Coax. as you go higher the coax starts getting better as many folks do not use optical and hence designers retain the cheaper optical.But many dac designers even claim that technically optical as a medium has maximum jitter)
So follow your ears and choose what sounds best to you
I also have the Lifatec Optical as well as Yamamura millennium digital Coax as well as an ASI liveline digital Coax
Out of my Aries Mini streamer, the Coax has more instrument separation and gives the impression of more details while the Lifatec is more wholesome and not as etched as the digital
This will vary from device to device as well as the SPDIF as well as Toslink can vary depending on the OEM.
My experience with both coax and optical is very very limited because I have always used AES cables for digital transmission. That’s what studios and broadcasters normally use.
However when I do listen to CDs it's almost always via the optical connection. Immediacy and a sense of vibrance is how I would describe the music vs the coaxial out.
Oh, that’s so sad! Difference between an entrepreneur and an investor.before they were sold off to a PE firm
despite that, the optical is still preferred![]()
AES is the best no doubt as it is the choice of audio professionals as well on those equipment where the AES is truly balanced. Apparently many use the same SE output into balancedI used dual AES which I found superior to a single AES. In dual, there’s one for left and one for right channel. Very few transports and dacs allow dual AES though. I believe I2S is the best possible connection but I have never heard it since I never owned equipment which allowed I2S connection
