Shure M97xE: bought new from Electronics Emporium, Mumbai, has may be a hundred hours of play. This is the replacement to the V15 series of cartridges and still in production.
Shure V15 III: (without the stylus) came with my TD124. Got the replacement stylus some months back from Ed Saunders but I never got round to actually using it. This cartridge has been out of production for a long time, and so qualifies as a vintage. IIRC, the reason given by Shure for its obsoletion was that it was increasingly difficult and costly to obtain the boron that was used in the cantilever.
Last night I suddenly remembered that I have this cartridge lying somewhere amongst my audio mess (tube light, anyone?
) and decided to swap out the workhorse M97xE.
The tracking forces are practically the same, and even cartridge weight differ by only 0.6 gms (the M97xE being heavier at 6.6 gms). So arm re-balancing was not really required, though I will fine tune it later.
Here's a quick first impression:
Straight off the bat, it is obvious that the vintage cartridge has much better higher frequency extension. There was a new found shimmer in the highs. The difference is not subtle.
It also has better low frequency extension. The bass on familiar tracks is tighter. But this is a bit subtle and not as pronounced like the HF difference.
It also digs out more details from records.
It is no better at rejecting groove noises.
I think after 20-30 hours it should improve. Right now the sound is a bit harsh as the stylus has put in only 4 sides worth of play.
Some helpful user on audiogon has written about this detailed comparison on audiogon which seems to suggest that the two are roughly the same. For the most part, I tend to agree.
Sure, the M97xE is a very refined cartridge for its price and get you pretty close to what the V15 offers, but it lacks that last bit of extension in the highs and the lows, and will not extract as much details. I now agree with Shure's claim of the M97XE being "audiophile" on the packaging.
Since the V15 has a recommended capacitance loading of 400 to 500 pF, I will try with this value (need to open up my phono stage to check if 400-500 pF setting is supported).
