Hi Saket, welcome to the wonderful world of vinyl.
Generally, any amplifier for audio listening consists of 2 sections, a power amplifier for amplifying sound to loud levels and a preamplifier for controlling the tonal quality of sound and prospective matching with various input sources like CD, Tape, Tuner, Turntable, etc. The input selector, bass and treble controls normally form a part of the preamplifier.
A phonostage is the specialized front-end of a preamplifier for use specifically with turntables for playing vinyl records. During the prime days (so-called) of vinyl in the past, amplifiers used to have built in phonostages. However these have been dropped from modern amplifiers and AVRs to keep costs down (as the manufacturers assumed that turntables were not in vogue anymore).
Yes, you would need a phonostage for your turntable. However please note the following.
When you say home theatre, I assume you'd be using an Audio/Video receiver. Most of these receivers do not have a phono input (except for some high-end ones). Hence you'll require a phonostage. You'll have to connect your turntable to the input of the phonostage and its output should go to an input on your AVR. It is as simple as that.
Some integrated amps, especially the older ones, have a built in phono stage. If you use such amps, you wont need to get a separate phonostage for your TT. Also, some of the modern cheaper TTs come with inbuilt phonostages which are usually cheap and not worth listening to. Your Technics SL Q33 does not have an inbuilt phonostage.
Phonostages are important primarily because of 2 reasons (to put them in lay-man's terms):
1) Gain (voltage amplification)
2) Equalization
As the gain of our Turntable's cartridge is very low, its feeble output voltage has to be amplified to some extent before your amplifier can get down to using the signal. A phonostage does this.
Also, grooves on your vinyl LP is cut using equalization standards laid down by RIAA. This equalization works on the principle of pre-emphasis on recording and de-emphasis on playback. A recording is made with the low frequencies reduced (as low frequencies require larger grooves on the LP, which will result in less space for the actual recording) and the high frequencies boosted, and on playback the opposite occurs. The net result is a flat frequency response for your amplifiers tone control to work with. You can read about this further at
RIAA equalization - Wikipedia, the free encyclopedia
All the very best.
Thanks, Reuben
			Hello Guys,
I am planning to get a used technics turntable- SL-Q33. The seller told that i would need a phonostage and amp. I am little confused. Is phonostage same as pre-amp? WOuld the technics not be having its own pre-amp or adding a preamp is necessary to the player to feed it to amp?
SO overall, i am a little confused that what equipments i would need to play music on the turntable.
I was initially planning to buy this turntable and a home theatre (or speaker system) to play my lps. But now i am confused that what will I need overall. Please help.
THanks in advance,
Saket.
