Connecting Denon X540BT to a Jamo E 8CEN.2 center speaker?
Chaos
Would it be ok if i connected a Jamo E 8CEN.2 center speaker to my Denon X540BT receiver? The speaker specifications at the back say 140W/200W @ 6 ohms for long and short term whereas my Denon supports 90W, and 130W @ 6 ohms.
I'm not expecting to drive it to it's full potential. Just want to know if it is safe to connect and test for a couple of days before i decide on getting a center speaker to go with the rest of my Polk set up.
The jamo belongs to my cousin and i will have it for a couple of days.
https://www.denon.co.uk/uk/product/homecinema/avreceiver/avrx540bt
http://www.jamo.com/products/e8cen-2
That is speaker power handling capacity..
Yes.. You can comfortably use the center speaker with Denon AVR.. The speaker is 88dB efficient.. So, shouldn't be an issue..
