Connecting Norge and Yamaha 363
hari
How do I connect both Norge 1000 and Yamaha 363 to Diamond 9.5 Fronts . The 363 does not have any preouts. Need your valuable suggestion.
You need to do seperate setup.If you are using DVDp/CDp, use anaout to norge in.
Use Digital out from DVDp to AVR.
Now you need splitter which can connect either Norge OR AVR363,one at a time.
If splitter is not available(or as i think, it may degrade audio quality due to multiple connections), you can you use the same method as advised by spirovious with the difference that you have to take care not to put on both amps at the same time. i am using this method without any problem.
