Convert VRO files from DVD Recorder or Mini-DVD disc
jimmy8765
usa
.VRO files are created by DVD video recorders or camcorders with Mini-DVD disc using the DVD-VR format. The disc has a VR_MOVIE.VRO file, containing the raw audio and video data for all video recordings. The recording metadata along with navigation data are stored in the VR_MANGR.IFO file. A backup copy of this file (VR_MANGR.BUP) is presented as well. VRO Codecs: MPEG2, same as VOB but uncompressed raw video and audio. So in some cases you can treat the VRO files just like .VOB files, but in many cases you can not use, play or edit VRO file easily. And Cyberlink PowerDVD, InterVideo WinDVD, and Sonic Cineplayer are recommended for playing VRO videos.
Since many people cant easily play VRO files, and other people have problem import VRO files from Canon camera with Mini-DVD disc for editing, Pavtube release a powerful VRO ConverterPavtube Video Converter, which can help your convert VRO to VOB, convert VRO to AVI, convert VRO to MPG, convert VRO to WMV, convert VRO to MP4, convert VRO to DV, convert VRO to MOV, convert VRO to 3GP with perfect quality and without audio syncing problems.
Now follow this guide to starting your VRO files conversion and editing.
Step 1: Click Add to browse the documents for the VRO videos you want to convert from DVD Recorder or Mini-DVD Disc. You can add more than one file at a time.
Step 2: In the drop down list menu of Format, please select the output video format you want to get.
Step 3: If you want to edit your videos, please click Edit to get into editor windows and start your DIY process.
Step 4: Click Convert to begin converting the VRO files.
Now wish you have already known how to convert, play, edit VRO files from DVD Recorders or Mini-DVD Discs. Dont hesitate, download and convert now.
Pavtube Video Converter: Best software to convert video, convert WMV, AVI, MPEG.
Enable Samsung Galaxy Note 2 to play 1080p/720p MKV movies smoothly
Summary: This tutorial mainly explains you how to put and play all 1080p/720p MKV videos on Samsung Galaxy Note 2 by converting MKV to Galaxy Note MP4 videos.
Samsung Galaxy Note II features a 5.5-inch Super AMOLED screen, a blazing quad-core processor and support for playing HD videos up to 1080p. The 1,280x720-pixel resolution translates into a wide-screen 16:9 aspect ratio rather than the 16:10 aspect ratio of the first Note. That helps it fit right in with more standard graphics and video playback. However, due to the format limitation, sometimes you will find you cannot play MKV files on Galaxy Note 2 or missing audio when enjoying MKV movies on Galaxy Note 2. So how if you want to get these 1080p/720p MKV videos playable on your Galaxy Note 2? Get frustrated? Here you'll find the best solution.
The reason you cannot get MKV videos working on Galaxy Note 2 is simple: the default and downloaded Android Video player on the Note II cannot find a suitable decoder for the codec in the MKV file. To solve these problems, a great method is to convert MKV to Galaxy Note II compatible video formats along with some help from third-party tools. To achieve your goal smoothly, here i will take the all-in-one Pavtube Video Converter as an example to show you how to encode MKV to MP4 for viewing on Galaxy Note 2. The equivalent Mac version is the Galaxy Note 2 Video Converter Mac, which can convert MKV to Galaxy Note 2 on Mac OS X (Include Lion and Mountain Lion). Below is a simple how based on Windows screenshots.
