Cosmic COGRAM 4000 turntable
sudsen
Hi!
I have misplaced the antiskate counterweight of my Cosmic Cogram 4000 Mk II turntable.
Am looking for either a replacement or the weight of the counterweight so that I can get it fabricated.
Just can't use the turntable without the antiskate weight :(
Shall be grateful for any help on this.
Thanks!
You can use generic weights too, its not necessary to have the OEM. If you dont know already, perhaps seek to get the weight specs from an existing COGRAM 4000 user and order a replacement. There are quite a few online sources for these, a simple search will throw up some. Here is an example. You can get these made locally too if you have the time and energy to pursue it.
When working on mech equipment like tape decks, turntables, etc. It is very important to be very careful with screws, washers, weights, linkages, etc. OEM spares for these can end up being more expensive than the equipment itself :)
