Crossover for speakers @ Mumbai
sudhirbhosale
Hyderabad / Mumbai
Looking to buy good qulity crossover (prefer branded) for my sleakers. Where Can i get in in Mumbai?
Are Philips crossovers still available in market?
Thanks in advance
Thanks in advance
@sudhirbhosale... please don't go for stock crossovers. If possible, build one. There are plenty free resources available . You can use Xover Pro software to determine the value of the parts needed.
You can procure parts from diyaudiocart.com, in.element14.com. Get in touch with a local electronics shop and get the ckt done.
You can find lots of articles under DIY section of this forum.
Thanks in advance
What are the speaker for which you need cross-overs for ?. Are you planning a new build off. Or restoring or modifying any branded box ?.
An elaborate detail will direct you to correct directions or suggestions from everyone.:)
