cue file
srikarkav
chennai
Hi Guys,
It seems that flac files can be burnt as audio cd with cd text using Burrrn. Can someone tell me if i should bring all the downloaded files into Burrrn or only the cue file? While i can drag the playlist, it shows an error message when i try to drag the cue file. The cue file should be added so that the cd text appears on the cd isnt it? Can someone help here?
Thanks,
sri
You could use Nero for the job. For the CD Text if you had tagged the file while ripping you would have it in the FLAC file as well - but I am not one hundred percent sure of this.
Burrrn will do it and so will any s/w with CD-Text option. You can do it either way i.e. just load the Cue file and it will burn all the files or load the FLAC files (but in this case they should be tagged with Artist, Track, Album info).
Just make sure the cue file's in the same folder as the rest of the flacs. Then just drag, drop and Burrrn!! ;)
