DAC for Edifier R1850DB
Spinekar
Wanted to know from you guys if a DAC will help audio on these speakers which i am using for my desktop system,
3.5mm to 2 RCA to the speakers is the connection as of now
and if a DAC will help which one do you guys recommend
DAC may help but not certainly :) you can get one but can't guarantee whether you may or may not hear the real difference. I'm using Fiio K3 because it has a small form factor. It has a gain and bass switch which really increase a soft bass either on HP or on speakers.
It has a line out through which my Marantz PM5005 is connected :) however, I've also added a TEAC EQ between them just because some lighting looks good while music plays :)
Check this out! a FM selling his Cambridge Audio DAC Magic
If it is compatible with the desktop can we try an internal creative soundcard AE5 +. How it would compare with the external dac?
Creatives can be good for gaming/movies but can't give you stereo imaging well. However, the above DAC Magic is capable of nice stereo separation..it has both USB and Optical input. Can be connected to PC via its USB or Optical out.
Would Topping E30 be a good DAC for these speakers? I plan to play Hi-Res audio (mainly FLAC, maybe DSD) from synology NAS backup
I
It might work for you! I'm selling my Fiio K3 and it's a very good DAC. Including lineout for speakers/amp, has separate bass and gain switch, has a preamp and headphone amp so it's a multi-tasker :) you can see its reviews on the internet.
There are several points you must keep in mind here.
  1. A DAC works best with an integrated amplifier or a preamplifier/amplifier combination, and, passive speakers.
  2. The 3.5mm output of a PC/Laptop is meant for headphones. What comes from this port is an analogue signal.
  3. In general, digital signals are carried through USB, Co-axial, Optical and HDMI ports. RCA ports are meant for and can only carry analogue signals.
  4. If you feed the analogue signal to a DAC, in the best-case scenario, the DAC will switch to being just a preamp. In the worst-case scenario, it will fiddle around with the signal and may make it worse.
  5. Most active speakers have internal DSP in which they fine-tune the audio signal to suit the speaker driver configuration. For example, Edifier boasts of enhanced bass irrespective of the driver size. What they do is to enhance the low frequencies and pump them to the 4” drivers on the 1850. This model also has a sub-out, which means low frequencies are expected to be amplified and played by an external sub-woofer. So there is active frequency separation inside the speakers.
If you insert a DAC between the non-digital source and the 1850, you will certainly hear a difference. Good or bad is doubtful and very subjective.
If you can get a digital out from your source feed that directly to the Edifier. That will be the best option.
Thank you!
1850db sound their absolute best when you feed them digital signal through either optical or coaxial input. There is no point in adding an external DAC as analog input signal is converted back to digital domain and DSP is applied. There is no pure direct mode. And they don't sound that good with analog input, they most likely use a cheap ADC that completely negates any benefits an external dac might bring.
These speakers are ridiculously good for the money if you feed them digital signal. I would suggest either s2000pro or s3000pro edifier models for step up in sound quality if you prefer near field active monitors. Otherwise go for passive bookshelf speakers and integrated Amp combo. Pairing 1850db with a DAC would be a step in the wrong direction.
As I explained earlier (sorry for mixing my requirements in this thread), I plan to use digital source like flac and dsd files from raspberry pi4 to Edifier R1850db, don't have much choice but to use some sort of Dac to convert usb to rca. Unless there is some other device to convert usb to optical.
Did this, changed from 3.5 mm jack to a optical cable, the difference is huge, sound is a lot cleaner and there is clear separation, earlier it was muddy didn't realise that at all ( for over a year now)
@venkatcr and @jarneevan
Thank you!
As you already have pi4 with you, why don't you buy a DAC like Allo BOSS and add it in to the Pi. Then you can use Volumio or MoodeAudio as per your taste and fyi, this is what I have been using from quite sometime.
Again, you need to be aware of a couple of things.
1. The RPi was not designed to process audio and it does not do even a half decent job of it.
2. By itself, the RPi does not output audio signals through USB. The only audio output is a 3.5mm jack and sound from that is best avoided.
3. If you need any decent audio signal from a RPi, you need an onboard DAC and some sort of specialized OS and application such as Volumio, Moode etc. None of these will give you digital out.
4. Though something like RPi + Allo Boss will give you excellent sound, they are best mated to an external amp and passive speakers. Not sure how the sound will be when sent to active speakers. It will certainly not be as good as a amp plus passive speakers. I have explained the reasons in my previous post.
5. The whole RPi stuff has limitations in terms of HDD usage. Though theoretically you can use HDD of any size, the OS and application will take enormous time to tag anything over 500GB. If you files are elsewhere, you have to spend a lot of time moving files up and down as well as manually forcing the application to retag the files.
As I stated earlier, 1850db sound thier best when they are fed through optical or coaxial input. They have one of the sweetest midrange performances, specifically vocals, and quite an enveloping soundstage for their price point and may be even few notches up over their price point.
The biggest casualty when they are fed through RCA is soundstage. Even bluetooth sounds better than RCA analog inputs, it won't matter what external DAC one uses. BTW, streaming over BT sounds damn good on them.
I think there are some USB to Coaxial converters. I don't know about pricing though. Edifiers work well with either of the digital inputs.
But edifiers are meant to be used as one box solution. It won't make much sense to spend significant money on a chain that has edifiers. They have thier limitations. They can't compete with some decent passive bookshelves and an integrated amp.
Edit:
Something like this should do for simple conversion from USB to Coaxial/Optical https://www.amazon.in/dp/B00FEDHHKE/ref=cm_sw_r_u_apa_fabc_J9Q0T776ZT67FWB05RKX
This particular device seem to be compatible with RPi.
What about the Fluance A61 powered speakers (60 watts rms each) vs my Edifer R1850db (biamped 19w + 16w) rms for total of 35W rms each? I also run coax direct from Sony Bluray/cd, and sounds nice (mp3@192htz) as 2.1 system. I use the sub-out port to older 10" 400 W unit. Want more db level at times and curiosity about Fluance extra wattage. Both brands have internal DSP and DAC. Agree with you that Edifer RCA inputs are 40% lower output and fidelity suffers.
