Dali Ikon 1 + amp jolida JD 1701A combination
XDR
nagpur
hi,I recently had a look at Dali Ikon 1 Bookshelf Speakers ,amp jolida JD 1701A
Pls advice if any other better options so that I can have a look.
I enjoy listening to HINDI songs old and new
Budgest around 60,000/-
thanks
XDR
Also try out the Quad 11L2 bookshelves they are around 27K. But they will work only for a small room. I had heard it in combination with a wharfedale sw150 sub and it had a very nice sound. At around your budget also look at preowned gear specially speakers.
thanks
XDR
The only thing I would say about the Jolida is that it does not have pre-outs to connect a sub in its standard configuration. If you intend to use a sub for your music, then its going to cost extra to add this option in. I believe its about 100 USD for this option. Otherwise its one excellent hybrid amp.
